2008 A6 Tail lights work then don't. Please HELP!
Old Nov 14, 2015 | 08:12 PM
  #21
Jaykaren's Avatar
Default Here's what I did
I have 2008 S6. Tail lights giving error code but all bulbs fine. What I finally did was to plug and unplug the connector from the light housing multiple times? So here's my rationale. The contacts in both the male and female portions of the connection appear to be aluminum.Probably done for cost then weight. Aluminum corrodes over time BUT visual indicators are benign. By plugging and in unplugging multiple times you scrape off the corrision. NO ERROR CODES NOW. Life is good again.
Old Nov 22, 2015 | 09:46 PM
  #22
dpzee's Avatar
Default Yup. Clean the pins of the connector.
A 4-4ear belated thanks. this was 100% the correct answer for my 2008 A6. took about the time it takes to change a bulb (which i did several times b4 reading this simple solution). Thanks Plimag...
Originally Posted by plimagt3
The solution is far simpler and far less expensive. The problem is the ground connection in the cable that plugs onto the light assembly. You need to remove the light assembly and carefully clean the ground connection (cable and light assy). Ground is the brown wire. I used 600 grit paper (be very gentle; you only want to remove dirt and light oxide, not the plating) and laquer thinner. Reassemble and it works fine; no more warnings.
Old Nov 28, 2017 | 09:25 PM
  #23
apkesh's Avatar
I have had the same problem for over 5 years now and I am glad I found this thread. I took apart the light harness today and did not find anything that seemed like a 'ground pin'. Sorry, bit of a novice here. Can someone help? I have attached some pictures here. Can someone tell me where this pin/wire is?
https://ibb.co/jSSk7m
https://ibb.co/bN6OtR
https://ibb.co/fjMdSm
Old Jan 15, 2018 | 11:53 PM
  #24
Ais4Audi's Avatar
I fortunately haven't had this problem (yet) but a friend said he just added a relay and it worked.
Old Mar 21, 2023 | 01:15 PM
  #25
MillarQ3's Avatar
Default Q3
Done what the guy said to clean it out and it’s working perfect now and that’s with a q3 need to get a new one tho cause it’s so dirty
Old Mar 21, 2023 | 02:31 PM
  #26
Jaykaren's Avatar
Default Light corrosion on connector
I’ve had similar issue in past on both 03 RS6 and 08 S6. I didn’t “clean” them. I just unplugged and plugged a few times. That seemed to scrape off the light corrosion and re-establish a good connection. Put some dielectric goop in there as well.
Old Mar 22, 2023 | 03:55 AM
  #27
MillarQ3's Avatar
Yeah that’s it you should see the rods tho it’s like a holes blowed through it what a mess, but yeah man cleaned it up put back together and not a problem since, so thanks again to all yous
cnicolet10
Feb 14, 2013 01:54 PM
MLakinizer
Oct 4, 2012 09:28 PM
FishEye
Mar 25, 2012 03:13 PM
TagsAudi
May 31, 2007 05:55 PM
mypreludeisred
Aug 9, 2006 11:08 PM
