95 A6 Wagon Hatch Latch Problem
Old Dec 11, 2011 | 02:43 PM
barrystein's Avatar
Default 95 A6 Wagon Hatch Latch Problem
I have a 95 Audi A6 Wagon.
I am having a problem with the Rear Hatch.
I can open it from the inside.
The latch from the outside does not work however.
I have tried the different settings with the key lock, as I know one of the settings locks stops the hatch from working, but that does not fix the problem.
I have the inside covers taken off and I am looking at the mechanism, but I cannot figure out how it works or what is wrong.
Does anyone know how to find a drawing or diagram of the workings of the back hatch lock and releases, so I can diagnose it?
Barry
Old Dec 11, 2011 | 05:20 PM
barrystein's Avatar
Default found broken part
OK I found the broken part, it is a bronze colored tube of sorts that attached to the outside handle that has come loose. It appears something holding it broke. So to fix it I need to figure out how to remove the back wiper assembly and also the outside handle assembly. Any suggestions?
Old Dec 12, 2011 | 03:42 PM
NH_USA's Avatar
I had a problem with the hatch on my Avant and took it apart from the inside.
Bentley was almost useless -
I can't remember what it looked like but it was not hard to figure out.
I did not have to remove the wiper assembly.
I think there were nuts holding the handle in place --
Old Mar 10, 2012 | 02:18 PM
andrewsjr4's Avatar
Did you ever figure this out? I'm sure I have the exact same problem..
Old Mar 14, 2012 | 02:43 PM
sheppard2jt's Avatar
You'll need to repair it from the inside. The tricky part is getting the interior panel off. This post has just the basics for removing the panel.
quattroworld.com Forums: Avant Rear Hatch Interior Trim and Interior Panel Removal
From there you'll have to check it out and see what broke, It's usually a roller-pin looking round piece that breaks or the pot-metal lever that it sat in. Either way, a small nut and bolt or a bent nail usually does the trick. I did this same repair on mine a few months ago.
I do believe the wiper motor is in the way. You'll take off 2 nuts from the outside. First the small nut that holds the arm on, then the larger nut that holds the motor to the hatch.
It'll take a bit of time, but it should be an easy fix overall.
barrystein
Aug 3, 2014 02:59 PM
tgrichards
Mar 9, 2014 11:25 PM
barrystein
Apr 7, 2012 05:32 PM
robertmrome
Sep 20, 2007 07:19 PM
Silver98A4
Sep 14, 2006 11:03 PM
