Where to start
I have a 04 A6 S-line. I have no idea where to start. I would like to give the car more hp and better gas milage. I have looked for performance parts but cant ever find any. Are there any cold air intakes for the car? What about exhaust? I took it to a muffler shop and the guys there said they couldnt do anything. If anybody could help with any ideas that would be great. I'm not a big car guy, I can change breaks tires tie rods bearings and stuff but when it comes to ecu's and piggies and db's I have no idea what is being talked about.
cold air intakes arent worth a darn in this car. dont get any either because the fluid used to clean the filter contains oil that get stuck to the MAF which makes the car transmison act wonky.
best exhaust you can do is piggies which basically removes the filters from the cats which makes the turbos spool faster without the restriction of the filters. but if your state has inspections or emissions you will probably not pass them unless you get the CAT code P0420 and some other one coded out of the ECU or use spacers.
also im not sure if local muffler shops will do this job because messing around with catalytic conveter is a felony because of federal emissions laws. you might have to DIY.
as for the chips there are bunch of threads out there that can answer that better than i can. Do keep in mind that when you chip you are putting extra strain on the transmission. especially the automatic. the tranny goes from handling your 280ft-lbs to 400ftlbs. you may want to start saving for a new torque converter just to be safe. also you should get the audi TT diverter valves (710n theyre called. 40 a piece)
Vict0ar
Apr 3, 2014 08:38 PM
kinnes042
S4
Apr 10, 2013 06:29 PM
brit.mike13
Oct 17, 2010 08:26 PM
