98 Audi A6 Squeak...Brakes?
Old Jun 26, 2005 | 03:45 AM
Houndz408's Avatar
Default 98 Audi A6 Squeak...Brakes?
I just replaced all rotors and pads, and I can't seem to figure out where this damn squeak is coming from. This squeak varies with speed and stops i mmediatelywhen I start applying the brakes. Does any one know what this could be? I don't think it could have anything with the hub or bearing because applying the breaks make it dissappear.
-Houndz
Old Jun 26, 2005 | 09:23 AM
luiverpool@aol.com's Avatar
Default RE: 98 Audi A6 Squeak...Brakes?
Hello again Houndz, this is a hell of a coincidence - mine was doing this too 2/3 months after I replaced my discs and pads.
Again my brother sussed out that the pads had gone brittle and shiny with probably getting hot. He thinks that because the car is so heavy that if you are braking hard that the pads will get extremely hot and then will go brittle and shiny.
He says that the pads do slightly touch the discs when you're driving normally and that is what the squeak is - the pads rubbing against the disc but in their brittle state. Once you apply the brakes , because they go full onto the disc, then the squeaking stops.
What he did was he roughed the pads up so that they weren't smooth any more and that has done the trick.
You don't happen to have a slight oil leak as well do you - that's my third problem?????
Old Jun 26, 2005 | 07:04 PM
Houndz408's Avatar
I honestly don't know what it is. I have had this problem when I bought the car 2 years ago. Replacing the pads as well as roughing them up doesn't make a difference. On the same day I replaced them it (the squeak) started happening again. Could I have a bad brake caliper? Could it be a bearing? Oh yeah I also have an oil leak. But I know it has to do with a bad seal on the valve covers, which was supposedly replaced but still leaks and drips in the exhaust manifold. I am beginning to hate this car.
-Houndz
Old Jun 27, 2005 | 10:09 PM
rowingdude's Avatar
Sport brakes will squeak a little
Sammy~D
May 16, 2011 05:56 PM
wildgene789
Aug 17, 2008 08:16 PM
wahoos79
Feb 6, 2008 02:36 PM
selfemployed03
Mar 9, 2007 07:16 PM
kgsolomon1
Apr 18, 2006 11:12 PM
