Brakes - clunk and squeak
Old May 16, 2011 | 12:14 AM
Sammy~D's Avatar
Default Brakes - clunk and squeak
Vehical - 1996 A4 (B5) Quattro 2.8 Automatic.
I just put in new ceramic brake pads and had rotors turned in the front.
Now since the change it is a constant squeak squeak squeak, when I am not on the brakes but mostly goes away when I do hit them. But the next stumper is also since the change it makes a clunking noise sort of like a bad strut mount but it is not.
I am at wits end with this i have no idea how to solve the problem.
Any imput would be much apreciated and and answers will be tried.
REWARD LEADING TO SOLVING THIS ISSUE
Thanks Sammy~D
Old May 16, 2011 | 03:58 AM
hiwords's Avatar
your inner brake pad is loose. take things apart and pry the 3 fingers on the back of the inner pad apart and put it back together. as for squeaking, try some anti squeal. ceramic brakes are supposed to be noisy.
i don't need a reward cuz i'm a boss
Old May 16, 2011 | 05:56 PM
Sammy~D's Avatar
thanks that was the issue and the squeek went away cause it moved off the pad when i pried the fingers
wildgene789
Aug 17, 2008 08:16 PM
wahoos79
Feb 6, 2008 02:36 PM
selfemployed03
Mar 9, 2007 07:16 PM
kgsolomon1
Apr 18, 2006 11:12 PM
Houndz408
Jun 27, 2005 10:09 PM
