99' A6 quatro i need help
Old Nov 5, 2008 | 09:52 AM
NunesA6's Avatar
Default 99' A6 quatro i need help
my radio in my a6 just stopped workin it gets no power at all even the 6cd changer in the trunk doesnt get power. I checked the fuses they are fine is this a loose wire or amp problem?
Old Nov 5, 2008 | 11:41 AM
Jeffla's Avatar
Have you used a multimeter to ensure the head unit is getting power? I don't believe the changer will respond if the head unit is not getting power. So all the problems could be caused by the head unit.
What head unit does the 99 use? It is a singe din or a double din? If it is double din and your head unit turns out to be faulty, the dealer has them for $40.00 bucks right now. But that is getting way ahead of ourselves.
Old Nov 5, 2008 | 12:54 PM
NunesA6's Avatar
thank you for the help im not sure if its a single or double im a sped when it comes to cars i just drive them . i took a tester to the fuse itself and the box and it all got power all my fuses are good so i dont know what to do i might just bring it to an audi dealer see what i can do.
Old Nov 6, 2008 | 08:50 AM
NH_USA's Avatar
First -- You should have looked for help before purchasing an AUDI, but if you tell us where you live someone will be able to recommend a good shrink!
As for the fuses -- since you are a newbee - You need to check between both sides of the fuses and ground. If a fuse is blown -one side will have power and the other will not. If neither side has power you'll need to turn the ignition on.
Unless your really really rich and want to throw away your money -DO NOT GO TO A DEALER! find a local shop that works on Audi's and add them to your Christmas card list... People here can make recomendations for your area if you ask..
Old Nov 6, 2008 | 09:22 AM
NunesA6's Avatar
thank you very much
and im from Mass
Old Nov 10, 2008 | 06:19 PM
NunesA6's Avatar
any1 got wire diagram of that or were i can get one?
Old Nov 10, 2008 | 07:13 PM
NH_USA's Avatar
Where in the state of mass confusion?
Old Nov 10, 2008 | 10:37 PM
NunesA6's Avatar
burlington,ma
Old Nov 11, 2008 | 04:24 PM
NH_USA's Avatar
There are some good shrinks in N Billerica on Esquire Road next to where I work!
As for mechanics - When I don't want to do the job myself I use Bill at J&R in Lowell (978-441-0404) and get 90% of my parts from Force Five in Concord NH (603-223-6700)
I'd share a diagram with you but My docs only cover the A6 C4 up to 97..
Jiversurrey
Sep 4, 2011 02:00 PM
rnbguy
Sep 10, 2009 12:47 AM
tijani
Jun 16, 2008 05:05 PM
n34829
Jun 18, 2007 02:49 PM
akindy
Jul 3, 2006 06:42 PM
