Sponsored by:
Sponsored by:
A6 2.7 Steering Wheel Controls
Old 12-10-2009, 06:37 PM
vidalkiss5's Avatar
Default A6 2.7 Steering Wheel Controls
I have a 2001 2.7t A6. and for some reason the steering wheel lights and controls have died. can't skip a track or raise/lower volume from wheel.
Im guessing this is a simple fix, u know, crack open the fuse box and replace a fuse. But in the manual, theres no instructions on changing a fuse for this problem, all it says is "heated steering wheel" and my 01' isnt a model that has this option. any ideas on which fuse, or something else that I can do to resolve the problem?
thanks, Vidal.
Old 12-11-2009, 02:03 PM
justinm001's Avatar
Have a vag-com? Usually there will be an error in the radio and maybe it needs cleared. Other than that there's gotta be a connection under the dash that could of came off. Does your horn work? check your horn fuse also they might be the same.
Old 12-12-2009, 09:33 AM
Diahvomihooda's Avatar
Default A6 2 7 Steering Wheel Controls
I replaced my intermediate steering shaft today and after I was all done, none of my steering wheel controls work or light up. I also noticed that my dash says " Service Airbag" Anybody know what I did wrong or any ideas? I think I spun my steering wheel too many times when I was taking the old one out and putting the new one on. Maybe I pulled a wire or wires when doing this. Im not sure....What should I do?
Old 12-13-2009, 11:57 AM
m000035's Avatar
The steering wheel controls have a controller in the relay panel under the dash by the driver's feet.
But I do agree with justinm001, a VAG Com is the Audi owner's best friend. Use a VAG Com to talk to your Audi to ask it how it feels! It will save you money if you keep your Audi.
Originally Posted by Diahvomihooda
I replaced my intermediate steering shaft today and .... I think I spun my steering wheel too many times when I was taking the old one out and putting the new one on. Maybe I pulled a wire or wires when doing this. ..
It is a good possibility you have damaged the "clock spring" wiring. I can't remember it from the last time I had the wheel off, but in the manual it looks like it is replaceable.
Old 12-14-2009, 04:32 PM
vidalkiss5's Avatar
yep, justin the horn works fine. everything else works fine *knock on wood* it's just that with the controls. theres no warning signs or anything.
spike7171
09-27-2010 03:06 AM
SloRide
05-14-2008 11:17 PM
luvmysigp225
02-06-2007 04:27 PM
ctsphoenix
06-21-2006 06:51 PM
Lhillenb18
07-02-2005 10:19 PM
Quick Reply: A6 2.7 Steering Wheel Controls
