A6 2.7t Chip question
Old Dec 27, 2007 | 12:31 AM
dropscience's Avatar
Default A6 2.7t Chip question
I have three questions about the GIAC chip for the a6 2.7t
1. I have an S-Line, will I gain the horsepower added by the chip, plus the 15 the s-line ecu programming gives, or just the same numbers as regular chipped 2.7's?
2. What is the effect on gas mileage? With gas for me reaching almost 60.00 a tank, this is definitely a concern for me.
3. I have a Hi-Road extended warranty that covers me to 100k miles/5yrs. Will the chipping void this warranty? Is there a way to make the engine stock again so that the people doing warranty work cannot notice?
Thanks a lot!
Old Dec 27, 2007 | 12:38 AM
auditech79's Avatar
Default RE: A6 2.7t Chip question
As for being an S-line you would have to ask GIAC, my guess would be the extra 15 HP won't be there after the chip.
The gas mileage will actually be better if you drive it normally, if your stomping on it all the time (you probably will) then it will be less.
This will void all powertrain warranty if the dealer wants to check for it, but they are only gonna check for it if you blow your motor or something crazy like that.
Old Dec 27, 2007 | 12:47 PM
formulagigi's Avatar
In my experience:
1- Not sure, but guess it'd be the same.
2- my gas mileage is 1 to 2 MPG worse in 93 oct program VS Stock. I switched back to stock for a week on October to check just that.
3- it will void it they checl for it. Most Indy shop won't care and the warranty won't send anyone for small stuff... If you blow a turbo.... then problems!
Old Dec 28, 2007 | 05:58 PM
TI3VOM's Avatar
ORIGINAL: auditech79
The warranty laws are in favor of the consumer: the warranty will be voided only if it can be proven the chip/mod was a direct cause of a failure. Chipping clearly would not be responsible for all powertrain failures.
Old Dec 28, 2007 | 06:23 PM
auditech79's Avatar
ORIGINAL: TI3VOM
True, i should say any complete engine failures audi is gonna check for a chip, not so much a broken CV axle.
kraylon
May 24, 2008 11:44 AM
b5dub
Dec 28, 2006 01:41 PM
PAC2717
Nov 23, 2006 08:03 PM
prodrive
Oct 16, 2005 10:12 PM
trailboss
Aug 10, 2004 09:13 PM
