a6 97 quattro heating problem
Old Aug 22, 2007 | 06:06 PM
e_kade's Avatar
Default a6 97 quattro heating problem
my a6 temp light was flashin but temp gauge wasat halfway not movin up. so i procedded home, turned the car off and it proceeded to spill coolant everywhere. no radiator fan turned on.. so today i had read in the forum if the AC is on and both fans run, its not a fan, probably a fuse, relay , switch. ok well both fans RUN when teh AC is on. im not sure where to go from here any help would be great thanks
kade
Old Aug 22, 2007 | 08:59 PM
SSn's Avatar
SSn
Default RE: a6 97 quattro heating problem
Find out where the temp light sensor is located, I bet it lights up when chain gets disconnected, could be bad contact. There is also a temp sensor in the radiator or on the hose somewhere that turns the ellectric fan on when too hot. Check that.
Old Aug 23, 2007 | 05:40 PM
e_kade's Avatar
how do i test it?
Julianpnc
Oct 23, 2012 04:15 PM
Paul Rasmussen
Oct 10, 2012 08:51 PM
plumbous
Dec 15, 2009 10:19 AM
jj2345
Aug 21, 2009 11:06 PM
m.away1
Mar 10, 2008 03:05 PM
