A6 Electric Windows not working correctly...
Rear passenger window does not open/close with one touch button... It only opens/closes by a few inches at a time...so I need to press/pull the button repeatly to close/open?
I know if you pull the switch up to the top then pull for more than 1 sec it should reset the window but it is not solving the problem...
Any ideas will be gratefully received.
Thanks,
Thanks,
Well the 1+ sec didnt work and it is out of warranty...it seems that it happened to both Drive's control and at the passenger's control...so it seems to point to either the motor regulator at that window or the motor?! But the window does open/close but just having to keep pressing/pulling...
ORIGINAL: batman_robin
