A6 Electric Windows not working correctly...
Old Jul 5, 2004 | 03:15 PM
batman_robin's Avatar
Default A6 Electric Windows not working correctly...
Rear passenger window does not open/close with one touch button... It only opens/closes by a few inches at a time...so I need to press/pull the button repeatly to close/open?
I know if you pull the switch up to the top then pull for more than 1 sec it should reset the window but it is not solving the problem...
Any ideas will be gratefully received.
Thanks,
Old Jul 6, 2004 | 03:38 AM
ImolaS4's Avatar
Default RE: A6 Electric Windows not working correctly...
I would think the 1+ second trick would work. It may be that the switch is bad and will need to be replaced. Are you out of warranty?
Old Jul 6, 2004 | 08:29 AM
Well the 1+ sec didnt work and it is out of warranty...it seems that it happened to both Drive's control and at the passenger's control...so it seems to point to either the motor regulator at that window or the motor?! But the window does open/close but just having to keep pressing/pulling...
Old Jul 6, 2004 | 01:22 PM
ImolaS4's Avatar
ORIGINAL: batman_robin
Yeah... I think it's related to the regulator switch. It may come down to a simple R&R.
welshred
Oct 21, 2012 05:23 AM
shents
Aug 20, 2012 08:51 AM
sportback
Feb 10, 2010 08:26 AM
archangel
May 6, 2006 08:38 AM
lewishw
Feb 16, 2006 07:34 PM
