Sponsored by:
Sponsored by:
A6 intermittently pulls right.
Old 01-10-2011, 11:09 AM
joshlowe's Avatar
Default A6 intermittently pulls right.
I just bought a 2005 A6 3.2 Quatro with 73,000miles.
Two questions:
When I'm driving it most of the time it goes straight even if I don't have any hands on the wheel. Occasionaly it pulls right for a few seconds. Could this be the road that I'm driving on or perhaps a sticking brake caliper?
Also, I looked in the maintenance manual and I saw where most of the other Audi models have a timing belt that they recommend replacing at 75,000. It never mentions the A6 3.2. What gives? Does this car have a timing belt that needs to be replaced?
Old 01-10-2011, 02:04 PM
chefro's Avatar
Per Kevin's info from a diff thread, all 2005's 3.2L came with a timing chain.
As per your pull, you can check alignment, control arm bushings, ball joints.
If you don't hear any "rubbing" or "grinding" noise while rolling, then you can eliminate a sticking caliper or dust shield touching the rotor.
Old 01-10-2011, 05:07 PM
ppgoal's Avatar
Unless you tap your brakes and then notice a pulling, I doubt it is the brakes. If you are on a straight and "level" stretch of highway, will it track straight on it's own for a couple 10ths of a mile (hands off)? If so, I suspect the road has a depression in it from truck traffic that is pulling the car. The A6 has wide tires that seem to catch these easily, although my lighter Crossfire with wider tires does it more frequently.
Old 01-10-2011, 07:21 PM
Kevin's Avatar
The 05 3.2 has a timing chain. Please keep in mind that the 75K service is the major service on the 3.2.
Old 01-12-2011, 01:23 PM
joshlowe's Avatar
Thanks for the help guys. I had the shop check it out and they couldn't find anything so I'm guessing it is the road. It happens mostly on a road that has frequent bus traffic so I'm guessing it's pretty "rutted" out.
thirdeye4602
08-14-2013 07:12 PM
jarak01
08-19-2010 01:13 PM
cm.combs
01-02-2010 01:34 PM
cschoen7
09-21-2009 07:26 PM
TheBat
09-09-2009 05:26 PM
Quick Reply: A6 intermittently pulls right.
