A6 Not starting
I am very very amazed by the work you have done and its impressive !! Currently my A6 is experiencing fault code P0851 with P1724, other than having some jerks during hard acceleration, the car drive without any issue. Wonder if you can lend in some thoughts in this.. Appreciate..
No issue on starting the car actually, only thing EPC light up but car behave as normal. No spilling or whatsoever from internal as well, however from gearbox external, my driveshaft oil seals are leaking and oil residue has been all over the gearbox housing.. not sure if its because of that or this error is definitely pointing to the switch under the gear stick .. yes plan to strip the center console but labor cost charged by mechanic is quite high, so am buying time while saving enough for the job
