a6 rim specs
Old Jun 9, 2009 | 06:44 PM
psychosnoman's Avatar
Default a6 rim specs
I have looked all over and found nothing. What is the off set on a 2001 a6 2.8? I'm looking to get new rims but don't know what to look for
Old Jun 11, 2009 | 03:17 PM
anybody???
Old Jun 12, 2009 | 01:24 AM
chefro's Avatar
Old Jun 12, 2009 | 10:02 AM
SloRide's Avatar
My A6 has a 45 mm offset. The center hub is 57.1 mm with a 5x112 bolt pattern. I recently got aftermarket wheels for mine and found out that I needed different wheel bolts. Audi rims use a ball seat style bolt and most aftermarket rims use the conical style bolt. ECS tuning had the bolts I needed. Also with aftermarket wheels because they are intended to fit a wide range of cars you need to know that the hub will fit. Many wheels can adapt using different hub centric rings to match the spicific center hub measurement, 57.1mm in the case of Audi's.
Old Jun 14, 2009 | 10:06 PM
thanks chefro
thanks sloride for clearing that up. i might be askin you later for more advice lol but thanks
p4sty
Sep 2, 2010 12:17 PM
Ponch
Audi Q7
Nov 8, 2009 04:48 PM
gino123
Sep 14, 2006 06:42 AM
PhoneixFire13
Mar 5, 2006 11:29 PM
Mass
Feb 25, 2006 07:34 PM
