About To DO My First Oil Change
Old Dec 28, 2007 | 01:33 PM
beefski's Avatar
Default RE: About To DO My First Oil Change
I use Casrtol Syntec 5w-40 in my 96 a6 avant. It is approved for audi use. If you read the back of the bottle it will give all the manufactures that the oil is good for. A Mann or Mahle filter is fine. Dont forget to change the air & cabin filter and the fuel filter as well.
Old Dec 28, 2007 | 05:15 PM
frankinstyn's Avatar
ORIGINAL: beefski
Ummm....oil weight and approval are not the same thing. The weight of the oil for use depends on the design of the bears, seals, clearances, temperature and load. I don't want to get into it too much but to save you a little heartache down the road, try to stick to the recommended weights that are in your user's manual.
In a pinch however, any oil is better than no oil and for our engines....30 or 40 weight are the safest.
Old Dec 28, 2007 | 07:16 PM
Figgy1682's Avatar
well my manual said to use 0w30 but if you cant find it use 5w30 or 5w40. i always use synthetic , it was a leson learned in my honda after my cylinder walls started pitting. but MY perfered brand is mobil 1 cause its easily available and TO ME reliable. if redline or royal purple wasn't so expensive and hard to find around my way i would use that. the plugs i used were ngk iridiums and they were only 7 bucks a piece, when i first got them for my honda they were like 25 a piece.
Old Dec 28, 2007 | 08:16 PM
Mobile 1 is fine.
Old Dec 28, 2007 | 10:04 PM
Figgy1682's Avatar
the only reason i say royal purple or redline over m1 is cause i did the stupid finger test and could feel the difference, that doesn't mean under high heat consistent rapid movement it does the same thing.
Old Dec 28, 2007 | 10:50 PM
catdog's Avatar
I'm switching to Mobil 1 this weekend. What's the difference between 0w 40 & 5w 40? Does it matter? I live in central Texas, mild winters, hot summers.
Old Dec 28, 2007 | 11:44 PM
cr!mz's Avatar
5w 40 is better then 0w 40 for summer time... if too hot might even go 10w 40 but I don't think it matters that much... =)
Old Dec 29, 2007 | 02:05 PM
  #18
ET3 Callahan's Avatar
I use Royal Purple (10W-40 I think?), works greatfor my car. Anyone ever use slick-50 in a 2.7T?
Old Dec 29, 2007 | 05:00 PM
  #19
mperdue19's Avatar
Beefski -nicely done with the Josie Wales quote.
2003audiA4avant
Jul 13, 2012 09:32 PM
jaymac
Feb 1, 2010 06:24 PM
chefro
Mar 27, 2009 12:14 PM
sollyd25
Jun 27, 2008 01:52 AM
nc 2.7t
Jan 6, 2006 02:54 AM
