abs and brake light display after using brakes
Old Jan 17, 2008 | 05:46 PM
horhayjr's Avatar
Default abs and brake light display after using brakes
I have A 97 a6 wagon, Just had a front left wheel bearing put in, The mechanic also had to put in a new abs sensor and brass sleeve.
When i start car no lights are on in display, and abs works fine, after i use the brakes a few times the abs goes out and abs light and parking brake light come on in display.
Any help would be cool.
P.s i know the mechanic that did the work hasn't checked any codes
Old Jan 17, 2008 | 07:40 PM
2k S4's Avatar
Default RE: abs and brake light display after using brakes
CHECK FOR CODES Chances are the ABS controller went out, or the ABS sensor is not working properly.
amsouza222
Oct 10, 2008 12:37 PM
grapejuice
Jan 9, 2006 05:26 PM
