ABS kicking in at low speeds - please help
Old Mar 10, 2014 | 08:49 AM
russell1337's Avatar
Default ABS kicking in at low speeds - please help
i have a 2001 audi a6 quattro 2.7
abs kicks in at low speeds, i am stumped!
i changed the RF wheel bearing there was a tiny bit of play in it not much. all other bearings have zero play in them
changed all 4 abs rings on the axles - none looked bad but i changed them anyways
viewed abs wheel speed data - my scanner is a genisys and supports the vag com, i didnt see any of them acting up
i dont know what else it could be....should i start replacing wheel speed sensors?
thanks,
Russ
Old Mar 10, 2014 | 09:10 AM
RMD's Avatar
RMD
You have covered all the obviouse problems . I do not believe the sensores just fail.
I had a similar problem which turned out to be a piece of string wrapped around the stub axle.
Old Mar 11, 2014 | 11:47 AM
im wondering if anyone has seen a faulty module or wheel speed sensor cause this before i start buying more parts?
thanks,
Russ
WillA3
Jan 17, 2012 09:25 AM
kshington
May 16, 2011 07:42 PM
Project
Apr 22, 2008 11:38 PM
jukeit
Dec 14, 2005 03:58 AM
tcsaudia4
Sep 24, 2005 01:44 AM
