ABS module compatibility
Old Sep 9, 2008 | 01:39 PM
99A6's Avatar
Default ABS module compatibility
I have a 99 A6 with a Passat ABS module. Im throwing a code for the pass. side rear abs speed sensor. My shop recently picked up another 99 A6 with a bad ABS module and replaced it with one from a Passat as well and it just happens to be the same code as mine. Is this coincidence? I dont want to spend $125 on the sensor if its because of module incompatibility. Anyone have any ideas?
PS: the part numbers on the 2 modules are the exact same except the one from the Passat ends in P and the one from the audi ends in A if this helps
Old Sep 9, 2008 | 02:57 PM
oc_audica's Avatar
Just throwin out what comes to mind
Perhaps if the Passat was not a 4-motion, that may be a start.
It might be possible to adapt/recode the ABS module in Vag-Com, maybe there are different codes for the A6/Passat...
stang32
Feb 23, 2014 10:53 AM
cjpwood
Dec 1, 2013 12:34 PM
bigred'sB5
Apr 7, 2012 04:43 PM
bigred'sB5
Apr 5, 2012 01:09 PM
MetalMan
Sep 13, 2010 03:45 PM
