I posted a few weeks back about a problem with my ESP light flashing, and preventing my car from accelerating...Usually going uphill but not always...It seems to happen when driving around certain turns during my work commute..People said it was the ABS sensor...I adjusted one and cleaned it, and it seemed to help but this is still happening..NO ABS light at all, which makes me think its something else..I had a scan done and I got a MAF code..Cleaned it well, but no change....I dont want to buy something I dont need...My transmission guy has 2 Audis, and says if it was the ABS sensor, the abs ligfht would come on , and it wouldnt be an intermittent problem...Any body had these symptoms before???It mostly happens when My rpms are steady around 3,000(going uphill) but also happens under hard acceleration also around 4,000 to 5500...I also drove many times w the ESP off under the conditions that cause this problem and the car performs perfect...Boosts well,w no hesitations,and shifts well etc..
I searched around about the brake light switch problem, but I dont have any of the other symptoms that seem to go along w that problem..I dont have any accleration problems besides when the ESP flashes, and non when the ESP is disabled..Its prob worth a shot though since its a cheap fix...My cruise control hasnt worked though for a long time, way before this problem started..
just replaced the switch..pretty sure I did it right...Lights work, etc...Was a bitch though to get to it...But unfortunately, no change...Im really wishing I had someone who could scan my car while this problem was happening...
Tags
2001, a6, abs, acceleration, arms, audi, control, esp, failure, issue, light, maf, sensor, symptoms, uphill
- Camshaft position sensor a circuit range/performance (bank 1 or single sensor)
- Coolant Temp Sensor, Vac Leak? Any help would be great! Gauge or Sensor?
- Rear ABS wheel speed sensor rotor and ABS sensor ring for A4 '01 FWD. Any Difference?
- crank shaft sensor and wheel speed sensor
- 16514 P0130 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 1) A
