ADDING AUTO TRANS FLUID
Yes...consult your owners manual. Off the shelf ATF does not do the trick. AUDI has minerals in its ATF that help the tranny shift smoother or something like that. Make sure you use what the recommend. I believe it also has something to do with year/make/model but not 100% on that. Call your dealer.
Its a selaed transmission. There is no dipstick or fill cap. AUDI said it is a lifetime tranny needing no service. It must be miracle metal because every car I've owned, from domestic to foreign need their fluid changed. Heat, wear of the gears, bands and breakdown of the fluid result in a black, brackish fluid with metal shavings ever so fine. Ever wonder why the tranny pan has a magnet sealed in the bottom? Well, to catch metal shavings. This is old technology but wear happens, just like s*** happens [8D] and nothing lasts forever. My independent mechanic told me to change the fluid at 70k regardless. This guy has been in business for 25 years working exclusively AUDI, VW, and Porsche. I take his word on everything. On the flip side, I also happen to be friends with a master mechanic at my dealer in Seattle. This guy has been working on AUDI, VW, and porsche for 13 years. He told me that I would be replacing my tranny before 80k guaranteed. This conversation was off the lot and no BS if ya get what I mean. He told me he has replaced a lot of tranny's in the C5 lineup, all models. The first to go south is reverse and is preceded by shudder and slow shifting/hard shifting. He says the reason AUDI call it a lifetime warranty is that they are betting on replacing it anyways. So, with this logic, the fluid/filter change would be never have to take place and is futile due to the eventual failure. It might prolong the life but AUDI recognizes the flaw and that is how they justify it. Its cheaper for the dealer to replace under warranty than having a mass recall. Simple car business revolves around the bottom line = $$$. What boggles my mind is why they continued to manufacture these tranny's even after they recognized a problem. Anyways, I've had some problems and I can never get the problem replicated when I take it in. Oh well, bad timing I guess...LOL Screw it..If i breaks it breaks.
Turkeybaster115
Oct 31, 2009 08:53 PM
Exocer
Nov 28, 2007 05:40 PM
