Air conditioning...PLEASE HELP
Old Aug 20, 2009 | 09:12 PM
vrso2's Avatar
hmm, good price
U need to remove front bumper, and put radiators on service position. Then u get access to work on your A/C comp.
I need to do same thing grrrrrrrrrr
Old Aug 20, 2009 | 10:45 PM
csswitzer's Avatar
if your clutch went, check the orphis tube also. its right by the valves for the freon. just had my a/c compressor go and there were metal shards in the orphis tube, its like a $3 part.
Old Aug 21, 2009 | 12:06 PM
danmcc86's Avatar
Vrso2;
Can't you access the compressor from the bottom of the car? Once you remove the oil cooler(the thing the oil filter screws on to) it looks like it's right there. If you really have to take the whole front assembly off it'll be a lot bigger of a deal than I thought. ...But 'das Audi!
Csswitzer;
I dont think that will be an issue because it wasn't the clutch that went out, it was the coil that engages the clutch. So just electrical...not really mechanical. But ill prob get the $3 part...cheap insurance
Old Aug 30, 2009 | 09:13 PM
danmcc86's Avatar
Okay, This is what I did. First I decided that I could remove the compressor from under the car by removing the oil cooler. I bought the A/C Compressor off E-bay for $50 bucks.
Then I went to local Audi dealership and picked up all the necessary gaskets (two o-rings for the compressor[$3.50 each] and one for to go between the oil cooler and the engine block[$10]) After that I went to my VERY trusted mechanic and he quoted swapping them out for $100.
Did it and Works Great! All for a total of $170...
The cause DID turn out to be the compressor clutch coil which we diagnosed by testing the resistance between the ground(on the compressor) and if there is none...its blown.
Old Sep 2, 2009 | 08:55 AM
aliyork35's Avatar
may be the ac gas is empty. take your car to the mechanics
lumpyd
Jun 18, 2013 09:36 AM
1.84life
Jun 20, 2008 01:21 AM
godowninflames
Apr 21, 2008 09:26 PM
Robsa4
Oct 7, 2007 01:44 AM
S4Goose
Jul 2, 2007 06:33 PM
