Alarm goes off
Old Aug 3, 2007 | 05:18 PM
ritam's Avatar
Default Alarm goes off
Twice to day whilst sitting in the driveway locked up in 90 deg heat my alarm went of for no reason. 1999 A6 Avant Quattro with 50000 miles. Is this a common happening or do I have something that is activated that I don't know about. I've been reading the owner's manual but haven't found anything. Any ideas out here. ritam
Old Aug 4, 2007 | 06:20 PM
slee22's Avatar
Default RE: Alarm goes off
Do you have the windows open while it's locked? If so, when you lock the car there's a sensor that measures changes in the atmosphere which will set off the alarm if wind happens to blow in through the window. If you have access to VAG-COM you can raise the sensitivity level so it won't go off as much. If you don't have the windows open and it goes off, it could be a fault with your Central Locking System.
Old Aug 4, 2007 | 10:31 PM
cary12's Avatar
Yep, I agree. It's probably your interior sensor. Mine used to do that until I found out about the interior sensor switch. Try that and see if it helps.
Old Aug 5, 2007 | 01:01 PM
project13's Avatar
The switch is in the drivers door jam, next to the trunk pop button, I think it has a car symbol with some lines above it, a red light that lights up.
Does anyone know if there is a way to disable this function with out a vag com?????
Mine goes off to if we leave the dammn windows down and car locked, I hate it....
Old Aug 5, 2007 | 02:58 PM
slee22's Avatar
^^ I think VAG-COM is the only way...even with VAG-COM though, you can only raise the sensitivity, you can't totally disable it.
Old Aug 5, 2007 | 05:10 PM
project13's Avatar
I might try Fubar ing the button and see what happens...
Old Aug 6, 2007 | 08:29 AM
ritam's Avatar
I read about that switch in the owner's manual but the switch in my car does not have the button in it. There is a plastic 'thingy' in the pillar hole but it has no movable pice in the center, just a open hole with what looks like a plastic post waiting to accept some thing. No indication of a light being present. So the sequence is not clear, I hit the button first then shut the door and pess the remote locking button, right? How am I going to see the, 'light blink quickley for 3 sec and then flash slowly after 30sec', if I 'm outside the car? ritam
Old Aug 6, 2007 | 09:55 AM
project13's Avatar
sounds like you have a broken switch..... I have seen the tops of the buttons come off before, they look like its a square white thing, some times you can still push it though...
huggybearv1
Mar 29, 2011 05:16 PM
debby
May 1, 2010 07:34 PM
rplets15
Dec 28, 2009 10:45 AM
batanguenio
Sep 26, 2006 07:07 AM
Art
Jul 17, 2005 12:21 PM
