alarm has a mind of it own
Old Apr 13, 2007 | 01:28 AM
duckman's Avatar
Default alarm has a mind of it own
my alarm is going off by itself from time to time ,,mostly at work ,i can never catch it in the act ,,,is there a way to shut it off for good ,,i don't live in a bad area ,,just want to keep my remote and keyless entry part ,the switch for turning off if you have a pet in the car is no good ,so i can not use that ..any help out there ,,thanks
Old Apr 13, 2007 | 02:47 AM
Jeffla's Avatar
Default RE: alarm has a mind of it own
"the switch for turning off if you have a pet in the car is no good" do you mean the switch itself does not work, or turning off the motion sensor doesn't seem to change the outcome. If the switch doesn't work and you have access to a vag-com you can change the interior motion sensor sensitivity. I have to do this, because if it is windy out and I leave a window/sunroof open my alarm goes off sometimes.
If it is just going off randomly and turning off the motion sensor has no affect, get your hands on a vag-com if you don't have one and read the codes. It will tell you why the alarm went off.
Jeff
Old Apr 13, 2007 | 03:57 PM
2k S4's Avatar
Do you leave any of the windows or sunroof open? if so, shut off the interior sensor.
You can also Vag-com the alarm to be less sensitive.
Old Apr 14, 2007 | 10:10 PM
duckman's Avatar
thanks jeffla and 2ks4, the switch is broken bought the car used and slowly replacing and repairing minor problem's ,,, i am leaning toward the window issue ,,both time's i have been told about it, the windows were down an inch or so ,,i keep reading about the vag com ,and every body has a different way to get a copy or down load ,what all is needed to get started with vag com ,,,thanks for your help
Old Apr 14, 2007 | 10:19 PM
2k S4's Avatar
ORIGINAL: duckman
http://www.ross-tech.com/
You need....
A ODBII cable either USB or serial
A computer (laptop is best)
Software, you should pay for it, the shareware sucks.
niceguy101
Jun 16, 2008 11:53 PM
AudiOmaha
Mar 14, 2008 09:20 AM
QuattroPhilly
Feb 19, 2008 09:38 AM
scotts custom
Jan 14, 2007 02:52 AM
batanguenio
Sep 26, 2006 07:07 AM
