Any ideas on what would cause this noise on acceleration? (video inside)
Exhaust Leak?
Exhaust Manifold leak?
Vacuum Leak?
PCV issue?
Throttle Body boot?
Secondary Air Injection pump stuck on?
Had the mechanic take a look @ the exhaust during an oil change, didn't see anything obvious outside of one exhaust drain hole being a little bigger than the other.
I only remember noticing it after doing my timing belt service, along with the CTS (where I removed the throttle body boot to gain access to the sensor). I don't know if working on the car made me more aware of an existing issue.. or if it only sounded like that after.
I know it's not much to go on, just hoping someone may have had the same problem and know to eliminate this noise.
Much thanks, hxgaser.
Thanks for the tips, hxgaser.
Every bit of advice you gave me there was on point.
I just finished removing and installing the newly purchased fan clutch and sure enough, the noise is gone.
On a side note though, I think I got so used to the loud wind up that the car now sounds like it has a 4cyl motor to me lol.
Bless bro
Bless bro
Glad it worked out and you are very welcome.
Yes, I kinda like the noise from the fan clutch engaging. It makes the car sounds like a jet taking off. Also you are lucky that it failed stuck closed. If it failed the other way, then you would have had an overheating issue. It took me awhile figure that one out on my car.
TheDanimal
Jan 7, 2013 07:23 AM
TheDanimal
Dec 29, 2012 12:35 AM
Joe003
Dec 21, 2009 06:50 PM
