Audi a6 automatic transmission problem
Old Sep 15, 2008 | 06:45 PM
ANNDRE3000's Avatar
Default Audi a6 automatic transmission problem
I have an Audi A6 automatic. The engine revs alot when i press the accelerator without proportionate motion in Drive . It begins to move normally as i progress on the road. When i press the brake to stop it begins the same process again. When i put the gear in reverse the car moves properly. However the dashboard is not displaying properly. Please help
Old Sep 15, 2008 | 07:03 PM
oc_audica's Avatar
sounds like you need a new trans
Old Sep 16, 2008 | 10:25 AM
nemohm's Avatar
Model, year, mileage?
Old Sep 16, 2008 | 10:57 AM
formulagigi's Avatar
TC maybe. Vag it and post codes
Old Sep 16, 2008 | 07:12 PM
nothing77's Avatar
does the dash display PRND at the same time
Old Sep 16, 2008 | 08:22 PM
you're thnking he's... limping? Sounds like it
Old Sep 16, 2008 | 08:40 PM
Stone825's Avatar
Our Mercedes ML320 did this. When we would drive, the revs jumped to around 5 - 5.5K just to get the car moving very slowly and then once we got moving it was fine. I believe we had to replace the transmission on that car.
Old Sep 16, 2008 | 11:44 PM
nothing77's Avatar
2 courses of thought, first being that the TC seal is gone and the tranny is slipping, second the TIP range sensor, the second def will cause the tranny display to be fubarred. On another note Brice, I see your in for the smoked tails, I thought you were letting the A6 go?
Ryan
Old Sep 20, 2008 | 06:13 AM
ANNDRE3000's Avatar
Mates, the error code is P1748
AMANDA25
May 15, 2015 05:45 AM
caffel
Nov 20, 2014 10:07 PM
Omega78
Feb 24, 2012 03:26 PM
rm_gangster
Jan 25, 2010 05:10 AM
bart197
Dec 1, 2009 04:53 PM
