Audi A6 humming/buzzing noise
I have a 2000 Audi A6 with a 2.8 motor and it's making a weird humming/buzzing noise when accelerating. There is no noise when the car is running and standing still. It only does it when I'm accelerating and trying to pick up speed. Any ideas on what it could be? Please help.
where does the noise seem to be coming from? is it an engine noise? is it a wheel noise? is it an exhaust noise? do you hear the noise if you are sitting still and revving the engine, or only when moving. maybe your car doesn't know the words so it is just humming.
best guess is tires. check your pressures. make sure they all match. check tread wear.
good luck
good luck
If the noise you're speaking of sounds like a muffled buzz or metallic rattle and is only heard while acclerating or when the car is under load, you may have something loose on your exhaust system. Check for a loose exhaust band clamp or a loose or broken weld on any portion of the exhaust heat shield around the Catalytic converters, resonators, or mufflers.
good luck
good luck
I looked at my exhaust today and it looks like my exhaust flex pipes have a few small holes in them and I think I'll have to replace those soon. Could that be my problem?
TwoDraft
Jan 24, 2011 03:28 PM
les06
Apr 19, 2006 01:12 AM
