Auxiliary water pump
Old Feb 8, 2012 | 12:42 PM
JJAudi's Avatar
Default Re: Auxillary Pump
Thanks a lot. I'm in the Chicago area. NW Suburbs. If anyone in the area could do the job for a good price that would be much appreciated.
Old Feb 11, 2012 | 11:49 PM
ninetynineA6Q's Avatar
Default 2.8 Aux. Water Pump
My 2.8 has an auxiliary water pump, or at least something that looks just like the auxiliary water pump listed for it on partsgeek. I know because I just had to replace one of the crazy German dogleg, offset, two-different-diameters-in-the-same-hose water lines that are attached to it. I have no idea what it does, but it's there.
Old Feb 12, 2012 | 07:19 AM
ImTheDevil's Avatar
Link or pics? Maybe we can clarify what you're seeing.
Old Feb 12, 2012 | 08:54 AM
Default Aux Water Pump
Here are some shots of what looks like an auxiliary water pump. You caught me at a good time since I just did the timing belt and cam/crank seals yesterday and I haven't put the front of the car back on yet.
Attached Thumbnails Auxiliary water pump-img_0103.jpg   Auxiliary water pump-img_0106.jpg   Auxiliary water pump-img_0105.jpg
Old Feb 12, 2012 | 01:43 PM
ImTheDevil's Avatar
I think you're referring to the secondary air pump. That's an emissions device for cold-start. Nothing to do with coolant.
Old Feb 12, 2012 | 05:28 PM
I might believe you, but when I replaced the lower hose that attaches to this mystery pump, a very large coolant leak stopped. I'm not saying that couldn't have been a coincidence, but I just crawled under the car again and that same hose connects to a steel line that runs across the front of the oil pan area and then sweeps upward, connecting through another piece of rubber hose to the coolant reservoir. It's too bad it's not actually an air pump, because an air leak of similar proportions to my coolant leak would have been far easier to ignore for a little while.
Unfortunately, the fact that it's a coolant pump still doesn't explain its reason for existing. I know there are plenty of other vehicles out there that are perfectly happy with just one water pump.
Old Feb 21, 2012 | 04:25 AM
K_I_W_I's Avatar
It is a simple job to replace the Aux water pump and because i know the engine well now, it only takes an hour to replace.
I ended up searching the Bosch part # when i had the pump in hand and found it much cheaper and got the replacement for less than $80 which beats the $200+ that most places will ask.
Do some homework on the net first.
KIWI
Old May 1, 2013 | 11:02 PM
  #18
Melchizedek's Avatar
Originally Posted by auditech79
The 2.8L engine doesn't have an auxillary water pump, only the 2.7T does under the intake manifold. The mechanic doesn't know his *** from a hole in the ground, or he is trying to set you up for a major repair. Find a different mechanic.
I have a 98 A6 2.8. I have the evidence of this pump going bad. i'm half way through taking off the intake manifold (a lot easier said than done).
I ordered the pump, and now I think ordered the wrong one.
Can anyone confirm whether or not mine actually has this pump before I finish taking this manifold off?
Old May 2, 2013 | 05:41 PM
  #19
I figured out, mine does not have an auxiliary pump.
My leak was caused by a hose that blew off because the hose clamp was loose.
Old Nov 10, 2013 | 06:27 PM
  #20
Theiceman's Avatar
KIWI
simple on a 2.8?
please share your secret how you change this in an hour.
kwiniarz
Jul 6, 2014 05:22 PM
Retired
Mar 12, 2012 07:53 PM
simzjr
Mar 18, 2009 07:03 PM
mpdc_1
Feb 25, 2008 12:30 PM
M¥§T
Feb 11, 2008 09:19 PM
