Auxillary cooling fan...
Old Jun 4, 2008 | 07:39 AM
MiniSpdRcr's Avatar
Default RE: Auxillary cooling fan...
OK...so after 3 days of chasing wire I still dont know what is wrong
Old Jun 4, 2008 | 07:30 PM
a6hcw's Avatar
Did your auxilliary fan switch have the three pins or the four pins? The 1998 A6 may be wired differently than the 1998 A6 wagon, which has the three pin auxilliary fan switch and the AFC engine.
Old Jun 4, 2008 | 07:42 PM
MiniSpdRcr's Avatar
Well I just took it to the mechanic and he after 3 days found 2 corroded wires. Which at first did not give the relay power after he fixed those the relay got power. Now the relay is not sending out power, which I am sure the relay is down now. The part number of it is
807 202
EA4
4B0959 589
PA6GF30
D112-03
Can anyone please tell me where I can find one of these?? Other then the dealership.
Old Jun 4, 2008 | 08:58 PM
auditech79's Avatar
Your not gonna be able to find that relay from any other place other than the dealer.
You have to remember the price at the dealer isn't set in stone, the parts guy gets a percentage so you can talk the price down, usually cost to the dealeris about 40% less than the price they give you.
Old Jun 5, 2008 | 08:27 PM
a6hcw's Avatar
If your 1998 Audi A6 has the 2.8L AHA 30 valve engine, you may have a radiator fan control unit. Try looking up your car for parts at www.audi-parts-direct.com , for a picture. You may want to get that Bentley CD, as mine covers only the 1998 A6 wagon, not the sedan.
Old Jun 5, 2008 | 11:08 PM
a6hcw's Avatar
There are two possible radiator fan control units, so you need to know if you have or don't have an auxilliary water pump on a 1998 2.8L AHA 30 valve engine. To see a picture of the auxilliary pump try www.audicarparts.com .
There is also an auxilliary fan resistor which could fail. On my 1998 A6 wagon the resistor is only visible from below on the left side with the plastic sound insulation pan removed.
chris_rozier
Aug 29, 2013 10:10 PM
bass9
Aug 16, 2013 04:49 PM
MiniSpdRcr
Dec 1, 2007 06:53 PM
FALCOR
Dec 1, 2007 03:48 AM
jgm7507
Oct 31, 2007 07:33 PM
