Bleeding brakes with ESP
Old Jul 22, 2010 | 01:43 PM
oldmots's Avatar
Default Bleeding brakes with ESP
How can you tell if you have ESP 5.3 or 5.7? The procedure with the 5.3 which uses a hydraulic pump to work the ESP requires the use of the computer to cycle and bleed the pump and the 5.7 does not.
Old Jul 22, 2010 | 02:12 PM
oldmots's Avatar
Doing some research on this, it appears that the ESP 5.3 has another pump motor mounted directly underneath the ABS pump. I am assuming that the ESP 5.7 does not have this extra motor. Is this correct? Before I replace the brake fluid, I need to know if I need the computer to do it. I hope I hae the 5.7 so I can bleed in the usual way.
Old Jul 22, 2010 | 04:09 PM
nemohm's Avatar
VAG-com scan should return the module version?
Or ask dealers by the VIN.
1275 sprint
May 26, 2015 02:20 PM
steve53mg
B7 Models
Oct 15, 2013 01:11 PM
mac5217
B7 Models
Feb 7, 2011 02:49 PM
kevace1
Dec 28, 2009 01:09 AM
GT5 S
Nov 27, 2006 04:56 PM
