bleeding/puking coolant/ no heat!!!!!!!!!!!!!!
Old Dec 2, 2012 | 01:10 AM
jcfone's Avatar
Default bleeding/puking coolant/ no heat!!!!!!!!!!!!!!
ello I have an 97 a6 2.8 wagon changed water pump and tb 3 weeks ago. seemed to be fine had heat no leaks. car started puking out resivoir and leaking out metal piece that connects 3 hose at front bottom of engine ,and it shut off while my wife was driving she swears it did not over heat. changed t stat and fixed leak but still no heat and the puking out went thru 2 and a half gallons of water tryng to get air out to no avail.im fearful of bad head gasket but no oil in coolant thanks jesse
Old Dec 3, 2012 | 10:12 AM
jcfone's Avatar
Default 2.8 a6 wagon
so now took it for 15 min drive filled up water 1.5 gallons there and back heater core hoses dont seem very warm is there a valve that controls flow? also this is probably real bad sign steam from between valve cover and headers
BlueOvalKid
Nov 1, 2011 11:09 PM
cu52
Oct 28, 2009 11:50 AM
nhill2090
Aug 7, 2009 09:36 AM
Johnd3573
Jan 21, 2008 06:16 PM
