Blinker help
Having trouble with my blinkers. When I turn them on they blink one and a half to two times then stop? Anyone else have this problem before that can help me determine what could be causing this.
-Michael
-Michael
Fairly common problem. Sounds like your blinker relay is going out. Check out the following link for more info and (if you surf the connections provided sufficienty) do-it-yourself instructions on how to fix. Pay no attention to the "blinker fluid" commentary -- just people being silly.
Blinker Relay Problems link
I'm a couple of years late on this post, but if you are cheap like me, then take the hazzard switch apart and clean the contacts on the relay with only one set of points. They work fine after I did this.
I will repost if and when they do stop working again.
