Blinker help
Old Jun 13, 2006 | 10:03 AM
sntemp's Avatar
Default Blinker help
Having trouble with my blinkers. When I turn them on they blink one and a half to two times then stop? Anyone else have this problem before that can help me determine what could be causing this.
-Michael
Old Jun 13, 2006 | 11:23 AM
SouthboroAudiGuy's Avatar
Default RE: Blinker help
Fairly common problem. Sounds like your blinker relay is going out. Check out the following link for more info and (if you surf the connections provided sufficienty) do-it-yourself instructions on how to fix. Pay no attention to the "blinker fluid" commentary -- just people being silly.
Blinker Relay Problems link
Old Apr 6, 2008 | 03:44 PM
vinceb's Avatar
I'm a couple of years late on this post, but if you are cheap like me, then take the hazzard switch apart and clean the contacts on the relay with only one set of points. They work fine after I did this.
I will repost if and when they do stop working again.
irunktm
Oct 23, 2012 11:29 AM
Sublime865
Sep 11, 2008 10:32 AM
zankey
May 23, 2008 01:20 PM
duburban
Jan 18, 2007 06:31 PM
mhiest
Jun 16, 2004 08:06 PM
