Blinker Issues...
My blinkers are having some issues, not sure if anyone else has experienced the same problem...
When signaling sometimes the blinker will just stop working and shut off, or it will get stuck on and not blink, the signaling lights will just stay on... then other times it will just blink really fast!
anyone have any thoughts...
thanks in advance for any help anyone can lend.
You need to change your blinker relay..very common problem. The relay is part of the hazard switch on the dash. Get a putty knife or thin screwdriver and pop off the wood trim. Push in the clips holding the hazard switch and pull it out, or just pull on it really hard. Unplug the harness and replace.
I got mine here: http://www.discountgermanparts.com/A...itch_list.html
