Bose Concert Problem (2000 Audi A6 2.8)
Old Sep 1, 2007 | 02:28 AM
Audiz's Avatar
Default Bose Concert Problem (2000 Audi A6 2.8)
Hello everyone, i just recently got myself a 2000 Audi A6 2.8 Quattro a couple of weeks ago and i have noticed that only the front speakers are working. I have gone over all fuses, wires etc with a multi meter and everything seems to be receiving power & what not. I have also gone through all the manuals i received with the car including the Concert booklet yet nothing to trouble shoot. Now the stereo isn't faded to the front so thats already checked but when i fade to the back...no sound...so rear pasenger, rear parcel try & subwoofer arn't working. Any suggestions people? Thanx :-)
Old Sep 1, 2007 | 11:35 AM
seis29's Avatar
Default RE: Bose Concert Problem (2000 Audi A6 2.8)
this is crazy thought buti was having problems with my radio as well it wouldnt turn on the lights would just stay lit. i went to vaction for two weeks came back and my battery was dead jumped the car and guess what a was working !! the radio !!
try it u never know
Old Sep 1, 2007 | 05:59 PM
project13's Avatar
ya it could be as easy as disconceting the battery and reseting the system.
But I have a feeling that it has something to do with a fuse or something like that or a connector that came un done[]
Old Sep 2, 2007 | 03:50 AM
Audiz's Avatar
Hey guys, thanx for your reply. I have gone over all the fuses, plugs and they seem to be ok as i have tested them to see if any power is running through. Hmm this one is a brain buster. Any more idea's guys?
Old Sep 2, 2007 | 05:22 AM
techbod's Avatar
sounds like the rear amp is down
Removing and installing amplifier with bass loudspeaker (on right in luggage compartment) -R43- (BOSE) (Saloon)
Switch off all electrical equipment.
Remove ignition key.
Removing:
Remove luggage compartment side trim (right-side):.
Unplug electrical connector -1-.
Unplug electrical connector -2- at amplifier -3-.
Unscrew securing bolts -arrows- (5Nm).
Take out amplifier.
Unscrew bolts -arrows- at loudspeaker.
Unplug connector -1-.
Remove loudspeakers.
Installing:
Installation is performed in reverse sequence.
[IMG]local://upfiles/12092/5FB65E99D6474423BFC65A4DF3B13230.jpg[/IMG]
[IMG]local://upfiles/12092/29AF636E018849B392F9BB8E908FC0EE.jpg[/IMG]
Old Sep 2, 2007 | 06:37 AM
Audiz's Avatar
Alright so if i pull it out. How do i repair it or how do i replace it? Thanx
Old Sep 2, 2007 | 06:48 AM
techbod's Avatar
well if you can pull it out you can put it back but not sure if there is a fuse on the amp as its not realy what im into,
have you checked the resistance on the speaker wires I blew all my rear speakers once ( you could plug an old speaker in its place to see if its getting power
Old Sep 2, 2007 | 09:23 AM
techbod's Avatar
wiring diagram if it helps
[IMG]local://upfiles/12092/38557890F0B440A6BAF7D7F1D57177F2.jpg[/IMG]
Old Sep 2, 2007 | 11:00 AM
project13's Avatar
Kicking it always works for me....[:@]
You should check the speaker leads and see if you are getting power to them, if not see if your amp is reciving power, if the speakers don't have power to them, but the amp does, then most likly the amp is shot if not you might have a problem in the wiring from the deck to the amp.
If all else fails replace the whole system or add a aftermarketamp and new speakers. There are write ups on here how to do that
shockertt
Nov 19, 2014 12:30 AM
tmanley
May 23, 2014 03:36 PM
x00057906
Feb 3, 2011 09:38 AM
muddlehead
Nov 17, 2006 09:05 PM
BrownA3
Sep 28, 2005 05:23 PM
