Brake Problem, any help appreciated??
Subscribe
Sep 25, 2007 | 09:42 AM
Good day all
I have noticed that my brake pedal is hard when I start up, but after a few minutes of idlingit is back to normal. Sometimes I hear an air leak from the egine, after I have switched of the engine. It is almost as if the system is loosing air somehow. Could someone please exlpain to me what might be wrong. I had the brake booster overhauled, but the problem still persists.
Thank you for your input
Michael
Reply
Sep 25, 2007 | 10:31 AM
RE: Brake Problem, any help appreciated??
its normal hard when the engine is off and softens up when engine on but you say a few minuets before it goes soft? does the peddle seem like it has too much travel? if yes there is air in the system
Reply
Sep 25, 2007 | 10:51 AM
Hi Dave
I have to apply more pressureafteri have started the engine, this last for a few minutes (too long)and then only it seems normal. The pedal travel is fine.What could the"air leak noise" after a trip mean?
Looking fwd to your reply...
Michael
Reply
Sep 25, 2007 | 11:10 AM
it could be the vacuum pipe from the servo but it could be inside the cabin from the peddle area then its only a seal and you can buy kits but not an easy job
Reply
Sep 25, 2007 | 11:28 AM
im still thinking air in the system but the air sound could be from the secondary AIR system and would be normal
Reply
Subscribe
