Brake Problem, any help appreciated??
Old Sep 25, 2007 | 09:42 AM
Michael Knight's Avatar
Default Brake Problem, any help appreciated??
Good day all
I have noticed that my brake pedal is hard when I start up, but after a few minutes of idlingit is back to normal. Sometimes I hear an air leak from the egine, after I have switched of the engine. It is almost as if the system is loosing air somehow. Could someone please exlpain to me what might be wrong. I had the brake booster overhauled, but the problem still persists.
Thank you for your input
Michael
Old Sep 25, 2007 | 10:31 AM
techbod's Avatar
Default RE: Brake Problem, any help appreciated??
its normal hard when the engine is off and softens up when engine on but you say a few minuets before it goes soft? does the peddle seem like it has too much travel? if yes there is air in the system
Old Sep 25, 2007 | 10:51 AM
Hi Dave
I have to apply more pressureafteri have started the engine, this last for a few minutes (too long)and then only it seems normal. The pedal travel is fine.What could the"air leak noise" after a trip mean?
Looking fwd to your reply...
Michael
Old Sep 25, 2007 | 11:10 AM
techbod's Avatar
it could be the vacuum pipe from the servo but it could be inside the cabin from the peddle area then its only a seal and you can buy kits but not an easy job
Old Sep 25, 2007 | 11:28 AM
techbod's Avatar
im still thinking air in the system but the air sound could be from the secondary AIR system and would be normal
alister147
Mar 9, 2014 05:00 PM
mattp23
May 19, 2011 11:32 AM
jwalters103
Dec 12, 2010 10:50 AM
guku0701
Oct 1, 2009 02:19 AM
mad_circle21
Aug 28, 2006 03:07 AM
