Brake Question
Old Nov 16, 2007 | 11:02 AM
qttrcoupe's Avatar
Default Brake Question
Ok.. seeing that I have driven a 1990 CQ for many years... when I went to get parts.. I knew that I was getting the right things as the car was very specific. Looking at brakes for my 2001 A6Q 2.8... I must have a memory lapse or something but where do I find the brake code.. I mean there a like two or three different size rotors for the front so I need the code.
Also any thoughts on pads... with or without sensor wire? does it matter? My current ones must not have it because the wear is to the point I think it would have tripped it.
Old Nov 16, 2007 | 11:10 AM
techbod's Avatar
Default RE: Brake Question
is there a break code? the VIN should be enough or take the pads in and have them matched which is what I do on the older cars,
wire sensor for pad ware isn't that important on that age of car because most new pads dont come with it
Old Nov 16, 2007 | 01:21 PM
qttrcoupe's Avatar
I haven' looked at the vin vet... i am going to luch here shortly and willbut I was told when looking at parts Rotors and such... 2001 A6Q 2.8 has 3 possibilities and there are brake codes such as 1LF 1LE etc.. hs to do with rotor diameter..
like I said I havent looked at the vin vet.. maye it is par of the vin... and engine code or something... but everyone refers to it as a brake code. I have the option for pads with wires and without... when it comes to sensor wires. I jsut didn't want to throw any warnings or errors if they wern't hooked up to the pads.
Kyle
Quattro_1.8t
Jun 10, 2008 08:37 PM
jayson161
Jan 21, 2008 03:02 AM
tyleryours
Jun 1, 2007 06:16 PM
Barrington
Mar 22, 2007 06:25 PM
cannon64
Jan 16, 2007 02:56 AM
