buying A6 2.7T need some advice pls
Old Aug 10, 2012 | 10:53 PM
500's Avatar
500
Default buying A6 2.7T need some advice pls
Hello,
I am thinking about buying this one 2003 Audi A6 2.7T
What should I be aware of if I buy that model or what should I know b4 I buy it
Thank you
Old Aug 11, 2012 | 08:43 AM
blitzin247's Avatar
Default Turbos!
I would check to see if it has upgraded turbo's in case you don't know, factory has two k03 units....if they haven't been replaced, and hopefully, upgraded, then be prepared to drop a few grand on new turbo's. Also, be sure to check and see how long ago the timing belt was replaced.
I bought mine a few months ago (2000 a6) and am now in the process of doing a full stage 3 overhaul with motor and trans rebuild.
Good Luck!
Old Aug 11, 2012 | 10:22 AM
eejimm's Avatar
Read the top two posts in this section of the forum - lots of information there.
Most important thing is how meticulous were the previous owners on maintenance - my 2001 2.7t has 217K miles, but was dealer maintained it's whole life (by a really good dealer) by the PO and still has the original turbos, etc. in perfect condition. If you can't get the maintenance history, take it to an independant audi mechanic to look through it before you buy - will be money well spent.
Jim
Old Aug 12, 2012 | 02:32 PM
ppgoal's Avatar
eejimm gives excellent advice. I did not see the mileage - but timing belts need changing every 80k miles. There is also a lot of other basic maintenance I would suggest depending: change differential and transfer case fluid, change brake fluid (mfr recommended every 2 years), change all your filters. Drive it 50-100 miles to make sure no CEL pops. I'm at 206k with oem turbo and suspension, but I did replace the clutch, flywheel, and recently the cats. I overmaintain my car, but it is my road car and I frequently take it for 1500-2000 mile weekend trips. PS - It now needs a $700 SAIU pump, which I will replace this fall.
Old Aug 22, 2012 | 09:06 PM
500's Avatar
500
Ok guys thank you for ur help I end up didn't buy I would have to spend extra 1500 for new tires and breaks and rotors and there was leak next to the turbo
Fungeneer
Sep 5, 2010 04:48 PM
stelth3d
Apr 15, 2010 12:28 PM
Frails
Feb 14, 2007 05:18 PM
deniska
Aug 20, 2005 04:17 PM
mander
Aug 18, 2005 03:53 PM
