Buying used Audi, Bose radio and other issues
Old Sep 14, 2013 | 10:58 AM
puremeerkat's Avatar
Default Buying used Audi, Bose radio and other issues
Hello everyone so I found a nice deal on a 99 A6 and I'm likely going to pick it up Monday. It just has a few problems that I want to know if they can be remedied. Firstly the Bose radio works perfectly fine EXCEPT there is no sound playing from the radio. No crackling or anything. Also when turning the volume dial, no indication of sound level is present. Is this how all A6s are?
Last issue is the Airbag light is lit. No other lights are on just that one. Do you think the airbag is still functional?
Old Sep 14, 2013 | 07:26 PM
nm3210's Avatar
Airbag is probably not good and I would recommend getting the module (under the radio/AC controls) replaced. Usually very expensive unless you do it yourself (you basically get to tear the entire center console and half the dash apart! but it's not hard if you go slow and take your time). I would first of all get it scanned to see what's going on. Chances are that it has an internal memory error.
You'll have to explain the issue with the radio a bit clearer because you are very vague. You say it "works perfectly" and then says it doesn't play any sound from the radio? So I assume that the tape deck works? Maybe you have a CD changer in back that you tried as well? The only 'indication of sound level' is how loud the actual sound is, there are absolutely no displays anywhere of what your 'current volume' is. I kind of like it! I get a little OCD about having the volume on my TV at certain numbers so it's nice not to care. More information about the Audi Concert Radio can be found here: Ti Kan: Audi Radios (and check out the Programming Guide in that section too, it's very good info to have).
Old Sep 14, 2013 | 07:54 PM
Not good news on the air bag issue but for the radio, I mean the display and buttons all function but no actual sound comes out of the speakers. I have only tried the radio and haven't done a CD or tape yet.
CryptoStorm
Dec 28, 2013 07:02 PM
superaudi02
Jan 15, 2012 05:08 PM
jmwhelan11
Dec 4, 2011 08:35 PM
asaucedo3
Aug 9, 2010 08:29 PM
msa10
Dec 21, 2007 05:12 PM
