Sponsored by:
Sponsored by:
Buzzing Alternator when engine OFF
Old 12-30-2010, 10:29 PM
audik0's Avatar
Default Buzzing Alternator when engine OFF
Newbie here,
2000 A6 2.6L
Buzzing noise coming from Alternator after I turn off the car. Anybody know what is going on here?
thanks
Old 12-31-2010, 02:27 PM
ppgoal's Avatar
Neither of my Audis have a buzzing alternator. In fact, I've never had a car make alternator noise. If you're in the states, I'd bring it in to an Autozone or equivalent and have the alternator and battery tested for free. But the 2.6 sounds like a European engine spec, so not sure what to suggest (unless you meant to type 2.8).
Old 12-31-2010, 03:06 PM
bob martin's Avatar
An alternator shouldn't make any noise when it stops and there is no power to it. Does you battery run down after awhile? If there was an internal short in the alternator, I would expect the battery to drain.
Where, on the 2.8, is the vacuum canister? The parts drawing shows it but doesn't say where it is located. It could be the canister or a hose leaking vacuum.
Bob
Old 01-01-2011, 03:56 PM
audik0's Avatar
I know I'm a little confused myself. There is an auxiliary pump next to it too might be that...
Old 01-02-2011, 01:26 PM
roadrune's Avatar
There is "something" in my 2006 2.0 TDI buzzing after it have been shut down, i can only hear it under the car or with the bonnet open, it stops after a couple of minutes.
According to Audi-mechanics this is normal.
drdremob
09-07-2011 08:13 PM
TwoDraft
01-24-2011 03:28 PM
Tourbo24
01-23-2011 12:06 PM
Borden
07-16-2007 07:25 PM
Quick Reply: Buzzing Alternator when engine OFF
