Car accident - Snapped timing belt
Old Jun 25, 2009 | 08:58 PM
lip's Avatar
lip
Default Car accident - Snapped timing belt
Hey guys!
So I got into a car accident last friday. I rearended a Toyota truck at ~20 mph. I hit him with the right corner of my car. The top corner of the radiator broke the timing belt cover, shattered one of the timing belt pulleys and snapped the timing belt. What are the chances that the engine is ok? I know the 2.8L are interference engines, but i've also heard that Audi has some kind of emergency shutoff system in place.
Old Jun 25, 2009 | 09:25 PM
loach1's Avatar
Sorry - very likely to be bad news. Emergency shutoff system might be to kill fuel in the event of oil pressure being lost, or something like that? The engine takes quite a few cycles to come to a halt no matter how hard you try.
With a new belt installed you could do a leak down test on each cylinder and hopefully find only one head has bent valves. Odds of no bent valves are very slim.
Old Jun 25, 2009 | 11:57 PM
Midniteoyl's Avatar
the emergency fuel cut-off is for accidents, but its unlikely that less than 20mph would have enabled it.
Old Jun 26, 2009 | 12:10 PM
the G man's Avatar
Did the car shut of by itself right away?
Old Jun 26, 2009 | 07:05 PM
lip's Avatar
lip
Yes .
Old Jun 27, 2009 | 06:37 PM
a6hcw's Avatar
What year 2.8L engine? There are 12 valve and 30 valve 2.8L engines. In 1998 the sedan had a 30 valve engine, while the wagon had the 12 valve AFC engine.
Old Jun 27, 2009 | 07:04 PM
a6hcw's Avatar
See thread about broken timming belt:
https://www.audiforums.com/forum/sho...d.php?t=133974
Old Jun 29, 2009 | 06:40 PM
lip's Avatar
lip
It's a 99 with 2.8 in it.
Old Jun 29, 2009 | 06:44 PM
auditech79's Avatar
If you broke the belt with the engine running it would have at least bent 3 valves, the engine can't stop fast enough. The emergency shut off will trip if the front air bags deploy or if you flip the car. By the time your airbags deployed the engine would have already snapped the belt. Now if you didn't get your air bags deployed then the engine stopped because the belt was snapped and you for sure bent all kinds of stuff.
Old Nov 2, 2023 | 12:03 PM
trowinaka's Avatar
Hello! Hope you're doing well. And although sometimes it seems that some damage is minor, it is important to always remember safety. I regularly read accident reports and my heart sank every time. Let's work together to make our roads safer and reduce the number of accidents. Every little bit counts, and working together can make a difference. Road safety should always be a priority.
whitey117
Aug 16, 2012 09:13 PM
fruitcakesa
Dec 21, 2011 09:31 PM
Cris_A
Oct 3, 2010 11:36 PM
ttManz
Sep 20, 2008 01:47 PM
sullivan2
Aug 6, 2006 06:13 PM
