car wont start
Old Oct 20, 2009 | 05:17 PM
rsonistxl's Avatar
Default car wont start
i was just installing my subs, and my battery died cuz i had my radio on and car off, and when i tried to turn it on, it would die right away, and i did get to move it, i just had to keep my foot on the throttle, i need help asap
Old Oct 20, 2009 | 07:34 PM
rsonistxl's Avatar
i just finished installing a new pair of spark plugs and wires, and it still doesn't turn on
Old Oct 20, 2009 | 10:54 PM
nothing77's Avatar
I would go back to the sub install and look for any issues, If it was working before, but not after
Old Oct 20, 2009 | 11:35 PM
Jackmup's Avatar
Make sure the battery is FULLY charged.
Old Oct 21, 2009 | 08:19 AM
rsonistxl's Avatar
the battery is charged, i think that it might be a fuse, im about to knock out soon.. so i will deff check it out when i get up later, and i know that this issue that im having has something to do with the installation of my amp and sub, i might have some electrical problems..
Old Oct 21, 2009 | 07:12 PM
hxgaser's Avatar
You need to run a throttle body calibration every time you disconnect the battery. Basically disconnect the battery. Reconnect. Turn the ignition to on position without starting the car. You will hear a faint electrical motor sound moving around the throttle body. Wait for 2 or 3 minutes or until the sound goes away. You are done.
Old Oct 22, 2009 | 04:48 AM
rsonistxl's Avatar
i just tried this without disconnecting the battery and it didn't work, imma knock out now, so when i get up i'll try it again..
Dylan Cure
Sep 4, 2012 04:21 AM
zslatcher
Oct 24, 2011 06:15 AM
Billydakid
Oct 29, 2010 02:40 AM
