center dash console lights go dim as car warms up
Old Apr 30, 2010 | 08:56 PM
vanbragt's Avatar
Default center dash console lights go dim as car warms up
Is it a simple bulb replacement or?
Old May 1, 2010 | 07:14 PM
jhuffman's Avatar
My audi has a little dimmer switch that will dim the lights. If it happens as your car warms up its probably just a loose wire or a bad connection to that, if you have one.
Old May 2, 2010 | 02:07 PM
vanbragt's Avatar
Thanks, I will give it a try
Old May 3, 2010 | 12:32 AM
hxgaser's Avatar
Actually it is known issue. Connector for the center display is soldered to the circuit board and it becomes loose after awhile. Do a search on the forum. There are many threads, but basically it involves either sending your cluster in for a repair, doing the repair on your own, or just replacing the cluster.
Old May 3, 2010 | 10:30 AM
jhuffman's Avatar
Are you talking about the backlighting for the speedo and the tach or about the LCD display? hxgaser is right about the lcd display... I thought you meant the backlighting :S
Alexa01a4QS
Mar 16, 2009 11:10 AM
idfnl
Jan 4, 2008 11:09 PM
seattlea6
Aug 6, 2007 02:41 PM
ShawnP
Mar 22, 2007 05:34 PM
snow4fun
Aug 25, 2006 05:13 PM
