Changed Head gasket, now ticking sound!!
I have a 97 Audi A6 2.8 12V and I just got done changing the head gasket on the right side (sitting inside he car). had the head shaved by a hair line since it never overheated and put everything back together. Started the car today everything works fine but I can hear a small ticking sound, its very similar to when your valves are out of adjustment but I guess the hydraulic lifters on these arent adjustable!!
anyways did a compression test:
3) 180_____6) 172
2) 185_____5) 175
1) 190_____4) 180
as you can see the side I changed the gasket has about 10 more psi on average! is this whats causing the ticking sound? should I just play around with the timing belt tensioner to see if I can get it run smoother? tighter or looser?
any help appreciated,
thanks
3) 180_____6) 172
2) 185_____5) 175
1) 190_____4) 180
thanks
AudiTurbo
Jan 7, 2014 08:03 AM
evilkowz
10
Jun 22, 2010 11:48 PM
