Changing the Front Brakes 2005 A6
Old Dec 20, 2010 | 02:47 PM
AWJ277's Avatar
Default Changing the Front Brakes 2005 A6
Does any know where i can go to find out how or know how to change the front brakes on my 2005 C6 A6?? Having some trouble.. Thanks!
This is how far I've gotten so far..
Attached Thumbnails Changing the Front Brakes 2005 A6-img00013-20101220-1255.jpg   Changing the Front Brakes 2005 A6-img00018-20101220-1336.jpg
Old Dec 21, 2010 | 07:38 AM
bob martin's Avatar
You have to pull the two bolts that hold the caliper bracket to the spindle.
Old Dec 22, 2010 | 03:04 AM
AWJ277's Avatar
Thank you, i figured that out right after I made the post. Took me a little bit though...ha
Old Aug 30, 2014 | 02:10 PM
Sweet T's Avatar
I am trying to change the front pads on my 2005 A6 - I've taken out the two bolts but I still am having trouble removing the caliper from the rotor...do I need to loosen or take off 4 star bolts as well? I've tried to loosen but very hard - are these reverse threaded?
Old Aug 30, 2014 | 05:41 PM
ManyAudis's Avatar
Do not remove the star bolts, that will disassemble the caliper. You need to remove the pad retaining spring on the outside of the caliper. Once that spring is out the pads will probably catch on the ridge of rust on the outside rim of the disk. You will need to manually push the caliper piston back into the caliper. I typically do this simply by twisting the caliper back and forth about a vertical axis. Once the pads are a little loose on the rotor it should slide off.
ncarvain
Feb 15, 2014 02:07 PM
sollyd25
Feb 23, 2009 10:36 AM
LilRobb
Sep 10, 2008 10:28 PM
branstone
Feb 24, 2008 05:46 PM
