changing a hazard switch
Does any have link or know how to change the hazard switch on a 2000 audi a6? Also, are they a 7 pin or 10 pin? I want to change the switch because my blinkers are not working properly. thanks
this is simple.. if you carefully pop off that one piece of trim around the cupholder/hazzard button its exposed there.. then take a flat head screw driver and from the top pop it out and then disconnect it and reverse for the new one. get the 10 pin relay.
Yup this is really simple. I had the same problems with my blinkers. Did it two days ago. Took all of 5 minutes. I used http://forums.audiworld.com/allroad/msgs/91515.phtml as a guide. I got the part from http://genuineaudiparts.com/
Oh, and if you want the pics from the above mentioned guide, you can find them using the Wayback Machine http://www.archive.org/web/web.php
Code:
http://mywebpages.comcast.net/ryanjen1/allroad/console_trim.jpg http://mywebpages.comcast.net/ryanjen1/allroad/relay1.JPG http://mywebpages.comcast.net/ryanjen1/allroad/relay2.JPG http://mywebpages.comcast.net/ryanjen1/allroad/relay3.JPG
