changing a hazard switch
Old Dec 3, 2008 | 06:14 PM
sollyd25's Avatar
Default changing a hazard switch
Does any have link or know how to change the hazard switch on a 2000 audi a6? Also, are they a 7 pin or 10 pin? I want to change the switch because my blinkers are not working properly. thanks
Old Dec 3, 2008 | 06:54 PM
afstud6900's Avatar
Banned
this is simple.. if you carefully pop off that one piece of trim around the cupholder/hazzard button its exposed there.. then take a flat head screw driver and from the top pop it out and then disconnect it and reverse for the new one. get the 10 pin relay.
Old Dec 4, 2008 | 01:11 AM
sollyd25's Avatar
thanks alot afstud!
Old Dec 4, 2008 | 12:55 PM
cbock's Avatar
Yup this is really simple. I had the same problems with my blinkers. Did it two days ago. Took all of 5 minutes. I used http://forums.audiworld.com/allroad/msgs/91515.phtml as a guide. I got the part from http://genuineaudiparts.com/
Old Dec 4, 2008 | 12:57 PM
cbock's Avatar
Oh, and if you want the pics from the above mentioned guide, you can find them using the Wayback Machine http://www.archive.org/web/web.php
Code:
http://mywebpages.comcast.net/ryanjen1/allroad/console_trim.jpg
http://mywebpages.comcast.net/ryanjen1/allroad/relay1.JPG
http://mywebpages.comcast.net/ryanjen1/allroad/relay2.JPG
http://mywebpages.comcast.net/ryanjen1/allroad/relay3.JPG
rezron
Aug 27, 2017 02:59 AM
johneyy57
Nov 24, 2014 09:03 PM
holdin16
Mar 1, 2010 01:13 AM
Dj Spiel
Mar 11, 2008 01:17 AM
twenty8red
Oct 18, 2007 10:53 AM
