clicking noises, 2001 A6
Old May 18, 2009 | 08:42 PM
Matrick's Avatar
Default clicking noises, 2001 A6
hey everyone,
recently my a6 started making clicking noises similar to the ones it makes when blinking for a turn. the thing is, that it keeps doing these noises even after the turn!!! does any one know what this is related to?
Old May 18, 2009 | 08:52 PM
s31523's Avatar
If: noise comes from the outside, and sounds like you have a nail in the tire, and you have more than 60K miles on the car... Then you probably have an outer CV joint boot that tore and now the CV joint is bad. The CV joint boot is obvious to see bad. There will be grease all over the outer part of the wheel housing. Check it out. If both boots are clean, then it is something else....
Old May 18, 2009 | 08:59 PM
Matrick's Avatar
the noise is definetly in the inside.
Old May 18, 2009 | 11:59 PM
Midniteoyl's Avatar
Some relay... you'll have to break out the 'ol Mk1 Ear and hunt it down...
Old May 19, 2009 | 08:10 AM
s31523's Avatar
The hazard relay switch (center of dash board) controls the blinker. It clicks a lot if it is bad. Do your blinkers ever skip or blink real fast or not at all?
rr319
B8 Models
Feb 1, 2013 01:54 PM
chusaiyan
Aug 16, 2008 01:25 AM
bcmchong
Nov 12, 2007 06:03 AM
epsilon146
Aug 27, 2006 09:59 PM
TT Ko
Dec 12, 2005 01:02 PM
