cluster repairs
Old Jun 15, 2008 | 12:23 PM
jj2345's Avatar
Default cluster repairs
my cluster on my a6 went out all the lines are gone,is there anyway i can fix this problem without having to buy a new one
Old Jun 16, 2008 | 09:24 PM
joetm's Avatar
Default RE: cluster repairs
nope
Old Jun 19, 2008 | 10:58 AM
massboykie's Avatar
Member
ORIGINAL: jj2345
These guys have reman units : http://www.bba-reman.com
Or maybe salvage? some listed on http://www.VAGLinks.com
Cheers
Massboykie
Old Jun 21, 2008 | 12:30 AM
a6hcw's Avatar
Did you check if the instrument bulbs behind the cluster displayare burnt out? Shine a flash light at the display to see if it still is working. On my 1998 A6 wagon, the transmission range indicator and the outside temperature indicator had burnt out bulbs which were soldered dirrectly to the printed circuit boards. You can get replacement bulbs for those at Radio Shack.
Old Jun 21, 2008 | 10:44 PM
gmatov's Avatar
A6hcw,
Soldered to the boards? Both those are burnt out on mine. Think I will pass if that is so.
Trip meter won't reset, think I will have to start a thread about that. Like to have a direct number instead of calcs to figure mileage on fillups.
Cheers,
George
jj,
"All the lines are gone." What's that mean, anyhow? All the traces on the board, all the wires in the connector to it? Excuse me if I am dense.
Old Jun 22, 2008 | 02:20 PM
a6hcw's Avatar
The most common problems with the instrument clusters would be burnt out bulbs and dirty connections. Another problem with 2000 and newer, might be the immobilizer. See www.ross-tech.com and search for immobilizer.
What do you mean by " all of the lines are gone"?
For bulbs which are soldered on, there is a "desoldering wick" which soaks up the old solder. Once the solder is gone the bulb wires can be pulled out with a needle nose pliers. All you need is rosin core solder, the desoldering wick, a pencil soldering iron, a needle nose pliers,a wire cutter, screw divers, torq bit screw drivers, etc.
Most of the instrument bulbs screw out, but these arenot usually stocked at local auto stores.
Old Jun 23, 2008 | 08:00 PM
a6hcw's Avatar
Search the forum for "Instrument Cluster Bulbs", which gives more information.
Old Jun 24, 2008 | 12:26 AM
Keithr726's Avatar
The bba-reman option above seems to be a good idea for $200 and I'll probably do it when it gets worse. Right now my 04 has 57,000 miles and it dims when its hot out. AC works well as a temp solution .
asutherland
Jan 22, 2010 09:58 AM
1999audia4
Jul 30, 2009 09:35 PM
bubbasmurf84
May 24, 2008 12:57 PM
DEDMN_TT
Mar 10, 2008 09:29 PM
TetrickA4
Nov 18, 2004 02:10 AM
