cluster repairs
ORIGINAL: jj2345
my cluster on my a6 went out all the lines are gone,is there anyway i can fix this problem without having to buy a new one
Or maybe salvage? some listed on http://www.VAGLinks.com
Cheers
Massboykie
Did you check if the instrument bulbs behind the cluster displayare burnt out? Shine a flash light at the display to see if it still is working. On my 1998 A6 wagon, the transmission range indicator and the outside temperature indicator had burnt out bulbs which were soldered dirrectly to the printed circuit boards. You can get replacement bulbs for those at Radio Shack.
A6hcw,
Soldered to the boards? Both those are burnt out on mine. Think I will pass if that is so.
Trip meter won't reset, think I will have to start a thread about that. Like to have a direct number instead of calcs to figure mileage on fillups.
Cheers,
George
jj,
"All the lines are gone." What's that mean, anyhow? All the traces on the board, all the wires in the connector to it? Excuse me if I am dense.
Cheers,
George
jj,
The most common problems with the instrument clusters would be burnt out bulbs and dirty connections. Another problem with 2000 and newer, might be the immobilizer. See www.ross-tech.com and search for immobilizer.
What do you mean by " all of the lines are gone"?
For bulbs which are soldered on, there is a "desoldering wick" which soaks up the old solder. Once the solder is gone the bulb wires can be pulled out with a needle nose pliers. All you need is rosin core solder, the desoldering wick, a pencil soldering iron, a needle nose pliers,a wire cutter, screw divers, torq bit screw drivers, etc.
Most of the instrument bulbs screw out, but these arenot usually stocked at local auto stores.
asutherland
Jan 22, 2010 09:58 AM
